I have a 2005 MEP-831a with 18 hours, I tried to pull start with the decompression lever and it spins and pops back but doesn’t start (just about ripped my arm off!)
Is there a better way to pull start ? I did try to use two 12 volts in series but my jumpers are Chinese junk and wouldn’t carry the amps needed to turn over the starter. I will get some motorcycle batteries later this week and try that. Any suggestions are appreciated
update- I installed two 12v 17.5 amp batteries in series and started right up, it wouldnt shut down with the emergency stop or switch. I had to use the docomp lever. So my governer is not adjusted correctly i guess. Will work on that once my klopp controller arrives.
