Looking for a MEP803a side panel door
aredman
24
13
Indiana
Recently got a 803a and its missing a panel. If you are looking at the control panel, its the one on your right side. Thanks
Light in the Dark
5,923
MA
aredman
24
13
Indiana
Thanks for the feedback. Where are those doors located? Another question, anyone know what they are trying to do with these wires in output terminal area? Thanks
Light in the Dark
5,923
MA
My items are in Massachusetts. Those wires are a modification added (that was removed upon this machines removal from its previous use). You can either trace it back and remove the wires (and rehook stock) or just keep them connected together and tucked up and out of the way.
Guyfang
23,985
Burgkunstadt, Germany
aredman,
When you stand in front of any gen set, the control panel is in front of you. That means the door you want is the right side door. Makes it easier when you are looking for parts. Lots of folks thing the control panels the back side.
And I must say, the new door is mighty fine looking! I could not see any difference between it and a original part. Fine.
