Yes Tobash, I know of the gear reduction and the plan would be to entirely eliminate the OEM in back of a tranny (probably not the original...my starter vehicle if I mess with HMMWV is unlikely to be running).You need a body, not a frame. You realize that HMMWV axles don't go straight to the wheels but terminate in boxes that reverse the axle's spin direction and then drop down to the wheels?
The speed on the sand trail is something like 50 mph limit and the wide base semi is 80. I cannot believe how smooth the wide Michelins run too. I watched a semi close the other day that convinced me a highway truck hummer might be a fun project with the wide Dana 80 and the 22.5x14 rim.Get some 20 inch, 8 on 170 steelies and run two of your Sand Trails in the back if you still have them.
