abfisher1798
- 87
- 28
- Blythe, California
No.
Thanks. You spared me from another remorseful govplanet purchase.No.
Those are mrap 330mm hub pilot
The type below will fit that is nearly identical to what you posted. . Notice the oversized lug at the ctis. Also the tapered lug holes. They have only ever sold 1 on govplanet though. Part # AS-18280
I think I have 6 or 7 left. I will double check over the weekendThanks. You spared me from another remorseful govplanet purchase.
Now all I need is to track down a seller. If you know of anyone, I’m interested.
Thanks again!
I’m looking for tires and rims. I need to replace a couple wheels that are ruined and also have some for spares.Are you looking for tires or wheels (aka: rims) or both?
Thanks for the heads up. I plan to steer clear of them since they are not direct riots to the 1093.the XZLs in the listing you originally posted are xzl plus tires. Know that those are new with alot less tread depth new than a standard XZL
No. Only 2 MRAPs use budd pattern. Caiman and MAxxPro Plus. All others use 330mm hub pilot. This is much larger than civilian 285mm hub pilot found on semisI have these on hand. Originally installed on the IVMMD MRAP.
If I change out the tires, are these wheels compatible?
You bet.Always ask before a purchase....
