M915A2 Air Conditioner Red Dot 2012 rendition .... questions about
coachgeo
3,463
North of Cincy OH
very hard to search in here for AC and most people use that and not "Air conditioner" Tried searching for [M915A2 compressor] thinking that might lead me in the right direction ... but no go....sooooooo without further ado ....
Anyone have info on the AC designed for the A2 model? NSN 4120-01-542-6365. General internet search not turning up any specs or TM's.
internet grab pic
simp5782
Feo, Fuerte y Formal
9,385
Mason, TN
internet grab pic
It's a R2000 headliner unit
@zebedee has them for sale. Or did have a few kits
coachgeo
3,463
North of Cincy OH
thanks... now to find a TM for install to get ideas from. I already have the unit. Well half of it. Other half not yet in my possession. The half with any paper work lol
simp5782
9,385
Mason, TN
Red dot will send you the manual on it. If it's not on their site
jonesal
Mission Specialist
69
Brookings, SD
I'm installing that kit in my M923 that I bought from a fellow SS several years back. It fits perfect (even the condenser in front of the radiator - the brackets are there - they just need drilled) WITH THE EXCEPTION OF the compressor mounts. Piece of cake to modify what's in the kit to adapt to the NHC250. I will try and scan in the manual that came with the kit and post here. I will need time to do that though. Reddot has more documentation as well but you would need to contact them for it. TB 9-2320-273-13&P-2 documents the A/C for A0/A1s that starts on about page 200 if that helps. I've attached a pic of what is in the unit. Have many other pics if need more detail (like compressor mounts, etc. in teh kit). Good luck.
Al Jones
M923 and others
Brookings, SD
coachgeo
3,463
North of Cincy OH
appears it is about 17,000 btu.... and can be mounted many different ways..... IFFF it can; I'll likely put it on the dog house of LMTV on maybe a 3" riser full of insulation below it. Then it can blow right on the pilot/co-pilot. Thinking this cause two reasons- 1. it appears from others builds; its 17,000 btu is too little for cooling whole of LMTV interior so best to try to just cool the person.... and two cause cooling just the person compared to whole cab means you might can put it on lower setting and put less drag on the engine.
