Several Cranks To Start Cause?
NY Tom
819
Riverhead, NY
Well for me just push it down very little. Even at that temperature when cold.
I figured I would throw it out there in case you don't have a real bad problem.
These trucks have personality. ;)
SandBar
Full Time Patriot
756
231
GA/FL
Yup. Use Permatex to reseal. Make a new gasket from sheet gasket material from your auto parts. If you ruin the existing gasket.
Thanks, will dig into this tomorrow. Can I use the same dot 3/8 air line for whatever is inside this assembly?
SandBar
Full Time Patriot
756
231
GA/FL
I'm not trying to save any money at all :D just read a how to bypass the FDC and it said to use DOT 3/8" air line. If that's not a good choice I am all ears, as I was going to mcmaster carrs fuel line section before I read that.
Bill Nutting
1,282
Chesterfield, Mi.
I don't know much about the correct makeup of DOT air line. For all I know it's just fine to use. Whenever I am using rubber hose for fuel, I go to my local NAPA and buy fuel rated hose. Maybe it's not all that important, I just don't want to be wrong about it and the hose fail...
