MV Parts store fuel filter kit install/review
Oerthedge21
20
Northford CT
So after weeks of the kit sitting in my room I finally got around to installing it. For those unfamiliar, this kit converts the truck to a pair of spin on fuel filters, like the jatonka kit except I believe this a far better setup. This kit comes with all new fuel lines from the tank to the IP and a new filter bracket. With this kit you take out your old feed line, and the primary and secondary fuel filter bases. The new setup bolts into where the old secondaries went. The instructions were great, they included pictures too. Overall I would absolutely recommend this kit to anyone who wants to do it, installation was almost flawless, though I did have to modify two of the fittings. I believe it was designed for non winch trucks as the fittings that go under the IP don't clear the driveshaft. But all I did was cut the fittings off and use the hose barb fittings I already had on my old system. I also had to cut the fittings that connected the kit to the fuel return line, the fittings weren't quite the same, though my truck has been through a few people so my fitting may not have been original. Once again easy fix, just cut the old return line off the barb where it hooks up to the hard line at the frame rail, and used a piece of 3/8 fuel line from the kit fitting in the regulator T to the return hardline. I highly recommend this kit to anyone, I had asked about it a while back but nobody knew much. I had a few people message me asking about how it went after I bought the kit, but I had no answers since I hadn't installed it yet, so I figured a thread post would be a good way to spread the word. After the install my truck definitely runs better, the egts are up a bit and it has a little more power. Plus now you can run a much better fuel filter and a water separator for maximum fuel quality. The kit comes with a chart if all filters that for the filter mounts too. Here's a few pictures of the final product. I have completely removed the entirety of the stock fuel system, all fuel lines and all three filter canisters. Feel free to ask me if you have any questions.
cattlerepairman
3,354
NORTH (Canada)
Inquiring minds want to know...how do you get your truck up there? Long ramps? Looks like a great place to work on the underside! I seem to prefer pushing gravel down my collar every time I move under my truck and losing small fasteners between the rocks. Much more fun.
Oerthedge21
20
Northford CT
Lol it's a friend's garage, the truck blocks the view but there's doors on both sides so you can drive straight through his garage and out to the ramps. Though a set ramps long and strong enough to get the truck out there is something I certainly would like to see
SandBar
Full Time Patriot
756
231
GA/FL
This kit looks good, I noticed on the website it says the bracket needs modification for 5 ton MF application. Do you know what modification needs to be done for it to fit?
rickdavis81
85
Rich Hill, MO
I installed mine last week. It’s a winch truck and didn’t have to modify the fittings under the ip. Had to make a different return line though. But being 50 yrs old no telling if it was original or not.
Oerthedge21
20
Northford CT
I'm not sure, if you call or email then they should be able to tell you. I believe it was something with the driver side fender well but I can't say for sure
Oerthedge21
20
Northford CT
It likely varies for everyone, I had already changed some fuel lines in my truck to clear the winch driveshaft, and the LDS obviously wasn't original to the truck so I'm sure that changed up some stuff too. But the major stuff like the filter bracket and fuel line length is all correct, just comes down to very simple fitting mods usually
SandBar
Full Time Patriot
756
231
GA/FL
Thanks for the info. While i wait for the kit to arrive, what filters are on their list? Would like to get them ordered to have ready for install.
Oerthedge21
20
Northford CT
Can't remember now, this install was about a year ago. I have since sold the truck unfortunately and all the paperwork I had went with it. They were common filters though I just picked them up at Napa the same day, not terrible expensive either
