Just a few days ago when it was 20 degees here in tn i was doing my weakly crank the the 1083 up let it get up to operating temp put the transmission in forward and reverse to keep every thing lubed and operating but this day when she cranks up once the air starts to build the parking brake knobs are hissing pretty bad and this had happend a year ago but this time i push both valves in to release brakes and the hissing stops i figure everything all good so i pull the brake knobs back out to set the brake thought all is well till i put the truck in reverse and it takes off up the driveway like the brakes didnt set ! i usally stand on the ground when im putting the transmission thru its paces from forward to nuetral to reverse so fyi really check your parking break has actually set before you get out of the truck maybe someone on here knows what was going on with my brakes when freezing ????
