TacMac2012
- 135
- 43
- Wallburg, NC
Anyone ever had steering issues? Not sure if the steering box needs some sort of adjustment, but I have a truck that has a long 'pause' from when you put effort to turn the steering wheel before the power steering kicks in and it actually turns the tires. Once it starts it turns fine (not weak), but if you switch from turning left to right (or right to left), or stop turning then start again it lags every time. Not sure if there is a procedure to bleed the system, I figure it would just self bleed with use. It was drained of fluid when I got it.
