- 281
- 221
- 43
- Herriman UTAH
I did not like the process of changing the oil on these trucks. Having the oil shoot out the side of the oil pan and head straight for the tire seems like a bad idea.
Also, I am using 5 gallon buckets and the Cat C-12 holds a lot more than one bucket so then I had to switch buckets while the oil is flying out. Not much fun.
So I thought I would suck the oil out by using a transfer pump. I have done it with other vehicles and it is a lot cleaner but not a lot faster.
So I had a transfer pump and a large hose so I stuck the "suck" end into the fill tube on the engine. Then my plan fell apart. The hose will only go a few inches into the fill tube before it hits something and it cannot make it all the way to the pan.
Dang it.
So my plan B was to just bite the bullet and drain the oil the regular way. BOY! It made a mess.
Awhile ago I found a place selling the oil drain VALVES and I had seen them before I thought it would be great if they made one for the 7 Ton. THEY DO!
I bought one and it works great. Now I can turn the draining oil off and switch the 5 gallon bucket. Then turn it on again to finish draining. They also sell a hose that attaches to the valve so I can drain the oil right into the bucket without it ever getting onto anything including the floor.
So while the engine was empty of oil, I installed the valve. My next oil change will be fast, simple, and clean. I installed my valve on the passenger side drain plug because it seemed to have a little more room. Here are the photos that show everything.
This is the package for the valve and I also show the drain plug it replaces.
I know I used a lot of gasket sealant but I do not want it coming off.
This is the hose and a 90 degree fitting.
Better shot.
Valve and hose together on the truck.
I could use the 90 right at the valve and then the hose would point straight down but it seems better for me if the hose is by the tire because then it is easier to get the full bucket out from under the truck.
Here are the Fumoto.com part numbers.
Dang it.
Better shot.
