35Z-SGM
- 3
- 8
- East Central, Iowa
I have a 1028 that started up, I moved it, powered it down, and at the end of the day I went to start it. Dash lights illuminated properly, glow plugs functioned properly, turned ignition switch and everything died. No dash lights, no turn signals or 4-way, no relay action, no body lighting. I have charged batteries and power to the fuse block, starter relay and ignition switch connectors at the base of the steering column. I have no power to activate start relay and I am leaning towards the ignition switch since it acts as if the ignition is off completely. Am I on the right path here? I don't want to tear into the steering column if I am on the wrong path. Any experienced assistance appreciated.
