spankybear
- 911
- 93
- WA
Could it be done?
I was thning about something like that but I think the axle is further aft than the M1101. If I built a camper right with more weight forward I should be fineWhy not ! I think the first thing i would do before you ever set the box on the trailer is to put retractable stiff legs on all 4 corners like the 1101 and 1102 come with but a little stouter so balance wouldnt be a concern when the trailer wasnt hooked to the truck .
If It's not too much trouble to look I would appreciate it.I'll be working out front tomorrow and my 1079 and one of my 1082's are next to each other.
I'll have a look to see if it would actually fit with no other mods (beyond adding the lower captured spring mounts/retainers).
I've seen plenty of S280's chained to the bed but those are a tad shorter and narrower box. The bed would absolutely need to come off the 1082 to fit the 1079 box (unless you hacked off the front wall of the trailer, perhaps).
Put a tape to it and it would fit w/o issue.If It's not too much trouble to look I would appreciate it.
at quick glance the trailer chassis looks potentially more narrow than the truck chassis.... so the 1079's sub chassis may not line up with the trailer chassis.Put a tape to it and it would fit w/o issue.
Negativeat quick glance the trailer chassis looks potentially more narrow than the truck chassis.... so the 1079's sub chassis may not line up with the trailer chassis.
If the drop legs had hand cranks on them you could level the trailer for camping if terrain dictated and jack the trailer up in case of flat tire !I was thning about something like that but I think the axle is further aft than the M1101. If I built a camper right with more weight forward I should be fine
Ive got a good 989a1 i would trade for a 1095 if you run across one.Yes. 1095 would be better suited
I've seen four M1095's sold in the past (and two of them were wrecks).Ive got a good 989a1 i would trade for a 1095 if you run across one.
Yea i havnt seen but a few and would really like to get one if i could trade some of my other trailers 989a1 or a1082 both camo green . There was one sold a little while back from individual but it went for 5 or 6 grand i think i just couldnt part with that for a trailer i didnt give that for my truck .I've seen four M1095's sold in the past (and two of them were wrecks).
Compared to a thousand M1082's sold.
So they are in the realm of "Unobtainium" rare...
