- 3,823
- 5,923
- MA
The fuel bowls on these SUCK to bleed the air out of. I gave up on the screws on the two I worked on. Also, I found the arrow for the valve to be open was backwards or I just misunderstood it.Well it seems the first unit is putting out power, just not registering on the voltage gauge. So to test that is next. On the second unit I have to take the fuel bowl off, cant seem to bleed the fuel lines at all... so there must be some dirt dauber BS in there (it had no fuel lines on it).
Seems like all the MEP gauges are tough to source. Engine side and gen side. Engine side is easier to find a suitable and even better replacement but I've yet to find a source for any of the gen side gauges.Got them both going. One is perfect after line changes, one has a dead DC Voltage gauge. Seems to be a tough one to source...
