MKT-75 It started out that I wanted to make a tactical burger.
flyfishtrailer
1,041
Cool, CA
That's awesome.....I am sure there are plenty of folks that cooked on them that would not agree with me, but I find opening it up and preparing a feast is a lot of fun. Glad to see you have been able to get her up and running after that journey across the sea.
HUNvee
251
Hungary
I have a question!
Either the kitchen is fattened or the jacket has shrunk, but the velcro fasteners don’t touch.
What do I do with this?
SCSG-G4
PSVB 3003
3,378
Lexington, South Carolina
The pan in the second picture is what I use to make the 'poppabear' Chilimac in. For just one of those pans you would need about 2.7 kilos of macaroni, cooked and put into the pan, add 1.7 liters of ketchup, and two #10 cans of 'chili no beans'. The US #10 can is 18 cm high and 15.5 cm in diameter which usually holds 115 US ounces or about 3.4 liters. Stir well then put in the top of the oven until it starts to bubble around the edges. Then sprinkle 1 kilo of grated (we use mild cheddar) cheese over the top and continue to cook till the cheese has melted, then serve! Should be enough for 35-40 adults, or 10 teenage boys. If you make your own chili, you can vary the ingredients to suit your own taste. There should be a chili recipe in the TM 10-412 if you cannot purchase already made cans, should be in Section L (page 30 of the full index), item L 028 02.
SCSG-G4
PSVB 3003
3,378
I have a question!
Stretch them. You have three sizes, the longest goes on the sides, then the middle piece should have 'fire exit' painted on the inside - that part goes in the middle, then the smallest panel goes over the remaining part of the end. Remember, the military generally had this smallest part open so the soldiers could go up and down on the ends, not on the side as you setup. The fire steps for the cooks is setup in the middle of the rear of the trailer. The solid walls are generally only used in inclement weather. If it is mainly rainy then the screens are setup inside the walls and the bottom of the walls are held out by the eight stainless steel rods, while the screens are secured to the floor to keep insects out. Only in very cold weather would the walls be kept closed, and then you would be also using the cold weather skirt from the floor down to the ground to help the cooks feet stay a little warmer.
juanprado
2,922
Metairie/La (N'awlins)
Saturn Surplus has the original military reflectors. Maybe your USA friends can help you and ship?
HUNvee
251
Hungary
We got a Drash XB tent. The floor, lifting rods and stakes are missing. It hasn't been set up yet, so we don't even know which size. I think it could be 5XB.
Today we repaired the damaged rods in over 100 degrees in the sun. At least the epoxy dried quickly :)
New mission on Tuesday!
flyfishtrailer
1,041
Cool, CA
Nice....pictures tell the story though so share when you can
