jasonjc
- 289
- 83
- Gravette Ar.
Well I got the new bearing in. No one local had the "green" Loctite , so had to order it from McMaster Carr. There are more kinds of Loctite then you can think of. Ended up getting and using 680 , had a pic of the bottle but it did not come out. All the rest of it went back together OK. The hard part is getting the 14 roller bearing in the input shaft to stay put. Got it refilled with a mix of 40wt oil and lucas (8-1). Was spinning it by hand and did not see any oil getting into the 2nd gear holes so I pelubed it. Check the sifting in all gears and the PTO. All seem to work good. Now to get the lube trailer flipped back over and the wheels on so I can get it out of the shop and the deuce in. Then I can get the trans back in and all the other stuff hooked back up.
