missionexpert
- 5
- 3
- Houston/Texas
I'm trying to determine what are the correct part numbers for the u-joints for the rear drive shaft. I unfortunately have the rear one that connects to the diff is all worn out. I'm planning on changing both ends of the shaft at the same time. When I disassembled it I noticed one was labeled SPICER U58 at the rear and SPICER U55 at the front end of the shaft. I can't find these part numbers online. I've tried searching the forum but it will not let me search for u-joint since it is looking for the letter U and it's too short a term. So if it's already been discussed, excuse my inability to find it!
U55 and U58 look to be the same size visually, but I'm not sure. Auto parts store said 5-1330x. I'm not so sure.
It's a 1992 M998.
I also searched an NSN number and found 5-213X , but not sure if the NSN number I searched is for a front or rear shaft.
Any guidance would be appreciated!
It's a 1992 M998.
