Have a 002A generator. Sat for a couple of years.
Cleaned fuel tank and pump screens and attempted to start it.
Pumps run and fuel solenoid clicks only.
New batteries so put 24 volts to solenoid start wire and had a big spark at the battery.
Now found out the ground was not connected well. Tightened ground and with battwries connected the starter energizes and turns over.
Note the start switch is not on when this happens.
Did I burn up a diode?
