- 8,422
- 2,485
- Monrovia, Ca.
I can get some, Will be back there Saturday. LOTS of .....things....all over. Every time I get in it, my knees get bit.
Damn! Wish I had buddies with "spare" 10-ton trucks just laying around...must be niceI bought this 10 ton from a buddy of mine mainly for a spare part's vehicle for my 10 ton cargo truck.
Yes, Supply and return are re routed to the drivers side tank only. Pas side is drained, capped off and the cap tight. Also stenciled on the tank a warning to NOT use that tank.Reference post 39: If you are only using the left fuel tank I hope someone moved the return line over from the right tank. As built a M 123 feeds from the left tank and returns to the right tank which prevents one from closing the valve on the crossover line so you would only have to fill the left tank at the end of the day. This trick works on M911s which feed and return to the same tank but not on a M123.
If the right tank doesn't leak, it can be made into a handy hydraulic reservoir if you need to work either a dump trailer or RGN trailer with your tractor.
.Though technically a 20 ton, it fit better here than the 5 ton thread. Did the main coat and am planning on finishing up this old gal' today. Engine is a 08' rebuild Big Cam III and she was an Arizona truck so minimal rust. I'm jealous of how easy this engine turns over and idles it's just so smooth.
I want one of them too!Maybe there should just be a "Giant Truck" category. Here's our rather large heavy hauler:
.Ok, she's done now. I'd say that painting an M936 wrecker is more intensive due to the number of angled surfaces but there are certain areas on this M920 that you have to maneuver into unlike the others.
View attachment 832946View attachment 832945View attachment 832944View attachment 832943View attachment 832942
.Making progress on flatbed for Hemtt, kind of think something should slide between I beams??? Cooler for whiskey?
