M35A3 wheel beadlocks
Sgt Jiggins
Potato Peeler
205
Lynchburg, VA
Hi,
Apparently the beadlock to run 395/85R20s on an M35A3 wheel is not 7.5" wide. Nor 8.0" wide.
Before I pull the trigger on buying the correct size, and go through all that work, I wanted to ask: what is it?
Thanks,
SJ/JD
HDN
5,019
Finger Lakes Region, NY
I was under the impression the ones that came with the stock 14.5R20 tires would work with the 395s, but that's not the case? :oops:
I found your beadlock insert removal thread from a couple months ago and @tobyS mentioned something about different sized beadlocks. 10 or 11 inches wide? I haven't gotten a rim apart yet but I imagine they'd have to be close to the rim width.
HDN
5,019
I didn't realize the 5-ton super single rims were narrower than the A3 rims. But they're a wider diameter?
EDIT: Nevermind, I see the 5-ton bead locks are the same diameter as the A3. Just curious if they're lighter or they just use thicker steel.
tobyS
835
IN
The Henderson 20 x 11 are entirely rubber like Dave (Eastern) posted above. I have not seen steel ones for A3 wheels.
tobyS
835
IN
Just discovered that these A3 beadlocks, Hutchesin 11 x 20 have different weight. Now I see a difference in the thickness. Rubber of one is about an inch thick and the other is 3/4. The thicker would seem to put more pressure than the thinner one.
To me, this suggests that we have some choice in a really tight or not, beadlock.
For my mostly highway and farm, I'll stick to the thinner....a whopping 7 pounds less.
HDN
5,019
How much do both beadlock inserts actually weigh? I've heard 30-40 lbs.
HDN
5,019
Do we need bead locks in civilian use? I dread the day, I need to pull them out and reinstall in new tires.
Unless you're using a CTIS, I don't think so. I want to keep beadlock inserts installed on my tires with the thought that if I have a fast leak or blowout while driving that the tire won't separate from the rim, assuming the whole tire isn't destroyed.
HDN
5,019
Yeah I use CTIS, so they're needed then?
Unless you want your tires losing air and falling off the rim when they're run at lower pressures, yes :)
I believe the way beadlock inserts work is that they keep the tire bead pressed and seated against the rim regardless of tire pressure, keeping the rest of the air in the tire from escaping when the lower tire pressure would otherwise unseat the bead and break the seal against the rim.
I haven't gotten to the point where I've been able to actually see how these go in and out of the tire first hand, but I plan on trying the ratchet strap method when I take them out of my old 14.5s and install them in my 395s.
gringeltaube
Staff Member
2,476
Montevideo/Uruguay
Unlike the solid rubber runflats these "rubber band-type" beadlocks can be installed with bare hands and no tools required. Good lubrication (with tire soap) helps a lot.
