- 3,828
- 5,938
- MA
Not an excuse for the factory, but 2012 was the end of their contract. They weren't going to be reordering data plates for a contract that was about to end... so I can see how someone would have approved the plate installation (versus none... as the build calls out a plate there).Just got back from the 1600 miles trip to pick up the unit. Indeed the bottom data plate is wrong from the factory. The one above is the correct 60hz plate. The unit is not a reset unit. built 2/2012 never put into service. All of the factory paperwork including service manual are sealed in package. aux fuel line and grounding kit are on the unit. Got home last night and looked for a few minutes this morning only issue i see is the radiator cap gasket stuck to the filler neck and will need replaced. Batteries still were taped off of the machine so hopefully these batteries will take a charge. Thank you for all the replies
