Speedometer Cable / Jerking Needle
Action
1,561
East Tennessee
3.08 gear ratio in diffs
the speedo gear color matches the number of teeth, so there is only one color for a given number.
I have no clue what the number is. The part number given in the -387-24p manula should be correct. I would look and see if that is in your t/c before you order anything.
cg25713
51
New York
Hey Ya'll. Still stumped. I removed and checked the elbow gear adapter and the red gear inside the t-case - yes it is red. All looked perfect. I cleaned, lightly lubricated and reinstalled. At 20 it seems close to accurate but at 30 and 40 its still 5-6 mph fast.
I have one more question for those in the know. The adapter, or part #20 in Figure 421 of TM 9-2320-280-24P-2, has four equally spaced notches in the top to accommodate the half circle clip that holds it down (part #23 in the same diagram). This means the adapter can only be held by the half circle clip at two different positions. I have heard the term "clocked" and I see the gear numbers on the top of the adapter - can someone briefly explain this further?
Action
1,561
East Tennessee
If there are 4 notches, then it can be clocked in 4 positions.
dont use -280 manuals for your truck. You want the -387 series.
cg25713
51
New York
I've tried but its tough. Even with the adapter out. Thanks for all you're help. I'll try to look for the mark and maybe get some different gears to experiment with.
