- 3,828
- 5,939
- MA
Thanks to those who have committed. I am going to put the order in tomorrow morning. You have until then to add to the tally. Thanks
I’ll send you a PM now. Thanks!Tracking numbers were messaged. If anyone didn't get a PM from me... let me know. @bosko still waiting to hear back from you on the 4 you wanted, they are here. Thanks
I have ample stock of these and can send express shipping [overnight] $135.00 or USPS priority $120.00 please email direct to libbysales@austin.rr.com thanx mac/mcMy MEP-802A had a blue S1 that would hang in the start position so I started looking for a replacement. I found another blue one on the auction site for $90 and passed. I sent an email to Electroswitch: I wanted the NSN 5930-01-531-2976, Model 75902LV version. The folks at Electroswitch indicated that this is an active model and could be purchased. The quote I received looked like this.
Below is our quotation for this Series 31 Control, 75902LV. If you wish to order this control, please complete the attached credit card form, .......... Pricing does not include shipping.
75902LV
Qty: 1-4
Price = $97.45 each
Lead Time = 3-4 Weeks
Non-cancelable, non-returnable.
Quote is valid 30 Days, F.O.B. Weymouth, MA........
My inquiry started with a note to info@electroswitch.com. Include your address because they forward your inquiry to the Sales Person responsible for your geographic region: mine is East Coast.
Date: Sun, Jul 16, 2017 at 2:31 PM
To: info@electroswitch.com
Is your rotary switch 75902LV available? It is a Series 31 switch used in military generator sets as the Master Switch.
Thanks,
Bls
Pdf is the Electroswitch drawing, images show old and new switches, and the installed unit. The several Electroswitch people I interacted with were very helpful and made the purchase quite easy.....as long as you can stomach the cost. I wanted an OEM 75902LV and am quite happy with my purchase. Note the diode is not included with the switch - I reused the one that was on my blue switch.
Hope this info helps others with the dreaded blue switches.....
YUP. They work freely and I don't feel it takes undo force to operate them.When you say old style, are you referring to the blue plastic Kraus & Naimer?
Was leaning that way, guess I will have a spare plastic switch now.In my NOS 2009 unit, its outfitted with blue switches (only has 19 hours now since I've owned it). I will be pulling the blue switch out and using it as a part for a future repair... for whatever that's worth.
Phenolic keyed shaft on the plastic unit, all metal on the Electroswitch. I'm not interested in a failure at the wrong time, on my personal machine.
I have a 75902LV in the mail. I understand that the numbers correspond with the K & N Blue switch. I am going to use the diode #1 to #7. I am curious about the jumper that was on the K & N. Did you have to use it? I have not used schematics in a looooong time, but am busy re-learning.My MEP-802A had a blue S1 that would hang in the start position so I started looking for a replacement. I found another blue one on the auction site for $90 and passed. I sent an email to Electroswitch: I wanted the NSN 5930-01-531-2976, Model 75902LV version. The folks at Electroswitch indicated that this is an active model and could be purchased. The quote I received looked like this.
75902LV
Qty: 1-4
Price = $97.45 each
Thanks,
Bls
The 75902LV does not require any jumpers to be added to it. Simply put the diode across terminals 1 & 7 and then hook the wire harness wires up to the switch.I have a 75902LV in the mail. I understand that the numbers correspond with the K & N Blue switch. I am going to use the diode #1 to #7. I am curious about the jumper that was on the K & N. Did you have to use it? I have not used schematics in a looooong time, but am busy re-learning.
Thank you. I studied the literature and the schematic and concluded that must be so, but your real-life experience sealed it! I appreciate your willingness to share something even so simple and obvious.The 75902LV does not require any jumpers to be added to it. Simply put the diode across terminals 1 & 7 and then hook the wire harness wires up to the switch.
