- 3,496
- 3,376
- Brooklyn, NY
Electric IP and pump will cause grief.
You have the perfect block so swapping is questionable.
12K shafts are for heavy rigs weighing 12k. You don't need them.
Tranny swap with 700R4 vs 4L80E is a good idea. Advancing timing and flow rate on existing IP will give you what you want. Everything else is bunk.
Save your $. Fix your rig but keep the dependable parts and stop looking to "gild a lilly".
