- 3,676
- 3,699
- Brooklyn, NY
How loud is the motor noise?
Not too bad I can barely hear the exhaust at highway speeds, at low speeds it is obvious it has a big ass turbo, this is a totally different animal being it has a variable geometry turbo charger and a performance one at that.How loud is the motor noise?
Yea I have seen these guys before, disappointing they never lifted the hoods on ether of them..I'm almost certain the manual for my duramax block heater said it doesn't activate until -18C which is right around 0 F. ........The injectors don't need help until 0F and that is just nuts. The seat in the truck is frozen solid like a rock but the oil, bearings, fuel, def, ....everything keeps working. I ran in -40 always on a block heater and expected head gaskets to go but the duramax never let me down.
The only problem I had was the 2016 and burning up pulleys right off the lot. I'm sure they went to imported bearings being punched out in a sand factory. I always broke them in by the book so pulleys are something to wiggle and test for heat after a run. I was in break in mode in a brand new truck in the middle of the city with belt smoke just rolling out from under the hood. That's funny!
It's not easy going through a build like this so thanks again for sharing it and taking it to the end. We gotta see some video and stats on 0- 50 or 1/4 mile runs. 0-50 mph is easy with a camera pointing at the speedometer and 'youtube' having a clock set up to do the timing. My record with the deuce is under a minute. Here's an entertaining hummer vid mate.
Send it to us, we need it.I want to go riding but it has been raining here for about a week, I was lucky to get to Beeville and back dry Monday I unfortunately I have to treat this like a garage queen until I get the doors and top installed, they say rain until next Tue.
It is said,
"South Texas is in a perpetual drought only interrupted occasionally by torrential rain"
It probably wouldn't hurt to hit the diffs, hubs, brakes, etc with an IR temp gun after a 95 mph drive.Took it out for a 100mi jog this morning, this thing it a hoot to drive, it is SO much more relaxing driving at 2000RPM rather than 3000RPM.
All pressures and temps look great!
Spotted my propane guy on the state hwy on the way home and decided to "ambush" him from behind, I was pleasantly surprised at how fast she jumped up to 95.
LOL, yes probably so, did not last more than a few seconds, I am still running the original tires, I am waiting for by balancers to get here before installing the new Baja tiresIt probably wouldn't hurt to hit the diffs, hubs, brakes, etc with an IR temp gun after a 95 mph drive.
Everything but the wipers and fans are 12V, no reason not to, trying to blend the two wiring harnesses would have been a bastardized system to say the least.Mogman- this is an old thread and I was reading it just bc I was bored. But I am curious about the electrics, why did you convert everything to 12v??
Could you have fit a dual voltage regulator under the hood and ran a dual system?
Or do they make 24v starters for the Dmax?
re-wiring for all the lighting and windshield wipers and all that sounds terrible, I was thinking that going to LED you may have been able to keep the OEM wires (but I’m certainly unqualified to know)
Can’t wait to see it painted and with the helmet top, I’ve always liked those for some strange reason
It is the one in the picture above, a 1994 M1097A1 the top and rear doors are going on the Duravee.So you already have a new donor truck? Do tell
Thank you mogman.I was asked about if my truck had full time 4wd and if I towed with the Dmax.
I am using the original transfer case from the 2008 LMM donor truck, it is electronic, has its own computer and is shift on the fly, meaning you can switch from any mode to another and when the TCCM decides things are right it will make the shift, to say if you are sitting there spinning the rear wheels it will not shift into 4WD until the gears can mesh without grinding, pretty dang cool and handy for sure.
But it is only part time 4WD so it is in 2WD on the pavement.
I have not towed with the DuraVee but I did have a big S788 shelter on it which had tons of drag and had no issues with heating, I have never had any coolant overheating but there have been times when running against a cross/head wind that I would back off from my normal 80MPH highway speed to reduce EGTs even though they are not at the danger point for the Duramax, I would like to install a larger intercooler in my next conversion this winter if I can find one.
