weirdman
- 47
- 13
- Knoxville, Tennessee
No, only one bulb worked. But we were not getting anything at the connectors. We ordered some new bulbs, but we are stumped on the wiring to the headlights.
Yes. Very unlikely that the wire between the light switch and the dimmer is cut.Sorry not dimmer. 3 lever switch is what I meant to say.
Most often, as noted in previous post, these lighting and electrical gremlins in older vehicles frequently involve bad grounds. Or you can be the Army and put a boatload of FMTVs on the broad ocean for a month going to Iraq and find out most of the electronics are fubar from salt air corroded grounds.From the sound of it, when the service drive function ( 2 clicks to the right of "off") is lit, the lights on the back of the truck and the dashboard work. Nothing on the front in either high nor low beam ? Parking lights in front will remain off unless "park" setting on lower left lever is set. The problem is either in the dimmer switch itself or the power lead from the master light switch to the dimmer switch. This is circuit 16 in the diagram in post 3. Instrumentation to resolve this should not surpass the capabilities of a volt meter or a test light.
Eureka!!
Apparently the problem was in the foot dimmer switch. After taking it out and checking for ground, we cleaned the attachment area in the cab and undercarriage, removed wiring and cleaned, replaced everything, reattached....low and behold 24v at the headlight buckets.
Such an easy fix with all of your advice. Sorry if I confused anyone, not good at what Dad calls "nomenclature"
Thank you all for your help on a frustrating issue!!
Please stand by for beginner questions?!?
