- 1,579
- 541
- Greenback, TN
Has anyone had to replace terminals in the PDP? I burned one of the terminals where CB-79 plugs in due to a shorted wiring harness (still chasing it). The terminal is attached to the 24v buss-bar that runs along the rear, feeding the whole strip of 24v CB's. That buss-bar is covered with a slide-off insulating tube. If you have done this you know what I am talking about.
My question is, how do those female terminals attach to the buss bar? They appear to plug in to a flat terminal on the buss bar but do not want to come off. I have pushed and tapped on the terminal from the rear trying to unplug it but it does not move. The buss bar does not seem to unplug but it seems it has to.
Any advise?
Picture attached showing the end of the rubber covered buss bar and it's matching terminal (with the yellow latch). This is not the exact one I'm working on, just the easiest to photograph.
The terminal with the yellow keeper is easy. It's the terminal on the buss bar I need advise on.
Thanks.
Any advise?
Thanks.
