Husker67
- 7
- 3
- Middleburg/FL
The no. 2 generator belt hits the lower radiator hose even though the belt is tensioned. Is there a shield out there that I can mount on the hose to keep it from getting cut?
Well there you have it. I seen this Mans work he knows what he's doing. That is a respectable solution.I run the NAPA hose. Trim the radiator end to move the dip in the hose more centered on the belt...
Thanks, that is what I expected.If I remember correctly the M1010 has a special lower radiator hose. That hose may no longer be available for the M1010. But you could fabricate a shield very easy. Good Luck.
