- 1,200
- 457
- 83
- Spartanburg,SC
So let me preface this by saying that i had a catastrophic failure of the front drive shaft in my 1078 while at max speed on the interstate. Busted axle yoke, transfer case yoke and the driveshaft itself. Not a pleasant moment let me tell you. In the process of disintegrating, it knocked a hole in my transmission pan/module and I have to replace it. I have taken all of the bolts out and dropped it about an inch. But I can't figure out how to disconnect the main wire harness that passes through the upper flange on the transmission and is a part of the module. The plug you see in the photo may come apart but I haven't figured out how yet.
This is where it passes through the flange in the transmission
The main wiring harness in question and plug mentioned.
This is a plastic cover on the wires inside of the pan/module. It covers the wires inside.
