- 1,321
- 579
- Quantico VA
I was tracking down a flashing Wait light and figured out it was the grounding wire to my Nartron box. What happened is the rubber mounts for the box had crumbled and then let the bolts slack up. I intended to remove the box (batteries disconnected of course) and add rubber bushings all around, then tighten that very loose ground. Trouble is I could not unscrew the main connector for love nor money. I ended up backing out three of the four bolts (all had a loose rivnut and the fourth was inaccessible from the underside to grab onto) and managed to tighten up the ground wire.
How do I unstick the corroded and stuck main plug? I will have to replace the wiring harness end I assume, by splicing in a better one, but I'm at a loss to remove the screw plug without damaging the good box.
Thoughts appreciated.
Bulldogger
Bulldogger
