sirmax123
- 8
- 8
- Kharkov, Ukraine
Hi!
I'm still trying to repair the wiring in my M1008, and I'm trying to replace every wire with non-original (I'm using from Russian car VAZ). Reasons: 1. Almost all wires were modified by previouse owner. 2. It is extremely expensive to buy original parts and it took weeks to get them from the USA.
Questions are:
1. Need to identify 2 points on the original wiring - Black and Pink with Black
(do not sure point is the correct word - I mean multiple wires connected together, please see pictures below:
Black:
Pink with Black:
It looks like at least 4WD indicator lamp is connected to the "black point" - cable comes to transfer case and back to lamp.
Is it 4wd indicator?Or what is this (transfer case is on this picure)
The second question is:
I found a disconnected wire, it comes from the fuse box (with is broken in my truck ) to the left headlight (together with turn signal and others)
Could you please identify it?
And the last question is related to the transmission wiring :
I see 1 wire comes to something (red arrow) What is this? where wire come from? Why wire is not isolated (see green oval) ????
And what is near the yellow arrow? Is it an oil presser sensor on engine? Where wire comes from?
Please pay your attention - it may be not the original wiring which was modified (and modified in the wrong way) by the previous owner.
I'm trying to understand how it must be and modify according to my new wiring
Thank you!
Max.
Questions are:
Black:
Pink with Black:
Thank you!
Max.
