jimm1009
- 70
- 48
- Louisville, KY
That tow dolly looks great but it is a little light weight for that Deuce to go on there. LOL
Good Luck!
jimm1009
Good Luck!
jimm1009
Well, that didn't last long. Despite taking it easy the clutch lost all of its adjustment in a hundred or so miles of smooth highway driving. I am not sure if I should attempt to adjust it again. There seems to be something that is causing the clutch to lose its adjustment right away and I am wondering if that means that the disc or pressure plate or both or at the end of life. I am at mile marker 63 on Route 19 in West Virginia, parked on the grass.a clutch adjustment has me back on the road, at least for now. southbound on I79 in west virginia
.Well, that didn't last long. Despite taking it easy the clutch lost all of its adjustment in a hundred or so miles of smooth highway driving. I am not sure if I should attempt to adjust it again. There seems to be something that is causing the clutch to lose its adjustment right away and I am wondering if that means that the disc or pressure plate or both or at the end of life. I am at mile marker 63 on Route 19 in West Virginia, parked on the grass.
What town are you near? So we can find some folks near you.Well, that didn't last long. Despite taking it easy the clutch lost all of its adjustment in a hundred or so miles of smooth highway driving. I am not sure if I should attempt to adjust it again. There seems to be something that is causing the clutch to lose its adjustment right away and I am wondering if that means that the disc or pressure plate or both or at the end of life. I am at mile marker 63 on Route 19 in West Virginia, parked on the grass.
If it's not adjusted right especially at the linkage it could be wearing even with the pedal released..
Crazy question... I can't imagine the clutch wearing that badly in a hundred miles. Is there any oil coming out of the bottom drain hole in the bellhousing? Seems like something big would have to be happening to chew through enough clutch to go to nothing in that distance.
Here is a Google screenshot. I am about 55 miles south of Jane Lew and 18 miles north of Summerville. It is mile marker 63 on Route 19What town are you near? So we can find some folks near you.
Sutton?
Burnsville?
I am about 55 miles south of game blue and about 18 miles north of Summersville. It is mile marker 63 on Route 19. Here is a screenshot from GoogleWhat town are you near? So we can find some folks near you.
Sutton?
Burnsville?
Sounds like we all could use a friend like Dave.Here's an update. My Haggerty road side assistance plan provided 150 miles of Towing and my friends shop was 147 miles away. Even a blind hog gets a few acorns. A 25-ton wrecker brought the deuce to my friend Dave's shop where we dropped the transmission. The pressure plate was perfect the side of the clutch disc that faces the pressure plate was perfect but the clutch disc facing the flywheel was a disaster and it really chewed up the flywheel. Interestingly, there was no oil in there from the rear seal but there was a dribble from the rear of the valve cover. Someone said that it looked like the clutch has been replaced buy some one previously and that they did a substandard job of attaching the friction material to the clutch disc as the buttons were ripped off and that is part of what chewed up the flywheel. I ordered a complete clutch set, flywheel bolts, rear seal, whatever from Big Mike's and he had it to us within 24 hours. The flywheel is at the machine shop and hopefully it can be saved. I had to bail because I was just about out of days off before I have to return to work so my friend Dave is kindly going to put it back together for me in his shop. A friend will help you move, a good friend will help you move a body, and a fantastic friend will put your broken deuce-and-a-half back together for you. I will post some pictures when I can. At this point the plan is for Dave to store the deuce for me at his house while I arrange for it to be transported to Texas from Pennsylvania where it is now.
Amen!A friend will help you move, a good friend will help you move a body, and a fantastic friend will put your broken deuce-and-a-half back together for you.
Call Wes (@simp5782)At this point the plan is for Dave to store the deuce for me at his house while I arrange for it to be transported to Texas from Pennsylvania where it is now.
