Wipers question
osteo16
585
Evansville, IN
Just put my wipers back into service.. when I start them they want to go up.. am I missing something here?? I can put them on an park them on drivers side, but I know that’s not correct position.. I’m stumped.. almost like motor is
Reversed somehow... could it be in the linkage inside window frame?? I attached drivers side linkage closest to motor then passenger side in the back... I’m perplexed to say the least..
Thanks
Ocho out..
1988 M998
Action
1,557
East Tennessee
The wipers should be parked on the passenger side.
Are you installing them on the driver side and they go up? Or are you installing them on the passenger side and they go up?
osteo16
585
Evansville, IN
I put on passenger side and they flipped up... so I just temporarily put on driver side ... could someone have switched wires under truck that would make unit run in reverse ??
Milcommoguy
2,213
Rosamond, CA
Did you change motor and by chance put the drive paw indexed wrong? Now out of sync with stop position. Disconnect mechanics at motor and cycle motor to stop position. Place wipers in the stop position. Fussing with motor reconnect paw and cross fingers.
It's a puzzle. What else did you change? CAMO
Action
1,557
East Tennessee
Yeah. Remove wiper arms. Remove bolts holding wiper motor to windshield frame. Pull it out a bit. Remove the single nut holding linkage to motor. Rotate linkage connection 180 degrees. Put back on motor shaft. Put nut back on shaft. Bolt motor back in. Put wipers on in correct spot. Try wipers...
osteo16
585
Evansville, IN
Well, If we want to get technical here 😂
The unit was dangling by 1 bolt when I received HMMWV. I replaced all the plastic pieces on the pivots.. I will check the indexing.. Question is, even if I retard or advance the index, the output shaft will still be driving the wiper arms up when initiating the wiper motor. Won’t it ?? . The outputs the arms attach to are running up/counter clockwise..up ((( If seated in vehicle. )))). They should be cycling clockwise .. down...if my brain is functioning correctly.. Again this is if seated..
But I’ll check my components...
And as I sit here pondering mechanical functions in my head, the possibility of rotating the paw 180 might do the trick..
Because the new position will enable an initial pull stroke on the pivot arms instead of a push stroke...
I’ll keep posted..
Thanks
TOBASH
3,423
Brooklyn, NY
CamO Is less referring to indexing and more stating that you might be off by 180 degrees.
Also, remove the wipers and mark the spindles and see how they move. They should always park in the same position. Use that information to re-mount the wipers properly.
dhaumann69166
78
Hyannis, Nebraska
When I moved mine to the proper side I had the same issue. The metal piece that connects the motor to the arms that go to the wipers can be set in two positions. Set it 180° from how you have it and it will fix your issues. It’s only notched to sit either how you have it or 180° the other way.
