LoveThySpatula
- 7
- 3
- Marysville, WA
So, long story short, my voltage regulator was shot (200 amp generator, dual voltage regulator) so I replaced it with a brand new N3135 regulator. Now my voltage output is correct, however, an issue I had prior that was not corrected was that the idle would surge temporarily for about 30-60 seconds after start. You can see the voltage gauge on the dash drop to yellow, then surge to green, rinse and repeat for a little bit, but definitely under a minute. After which, the gauge and idle return to normal and I get dead-nuts-on output at the regulator and batteries.
The operator's manual states to let the vehicle warm up for about a minute - are these symptoms considered "normal" or is there something abstract occurring here?
Thanks in advance - I am pretty new to Humvee ownership and did search for a similar topic but to no avai l
