HMMWV Sweden
- 11
- 3
- Sjöbo Sweden
Hi guys..today my HMMWV started acting up,when i turn on the ignition the glowplugrelay makes it's normal clunknoise and the wait light turns on..but does not go off. After about 20 seconds i started it anyway and starts up right away as usual..but the waitlight does not go off until i turn the ignition off and the same clunknoise from the relay..so relay seems fine and glowplugs work so i'm thinking what controls how long time the glowplugs are active?,is there a sensor,thermostat,bimetal strip,timer somewhere that tells the nartronbox when to turn off the glowplugs??sensor in the engineblock,inside the nartronbox??,TSU acting up??and is it repairable or do i have to order new parts??
I have searched the threads here on SteelSoldiers but haven´t found much related to this issue in previous threads,pehaps there is one and i have missed it and in that case i apologise for that.
And also posted on FB in a HMMWV group but no luck yet so...(photo of the box in my HMMWV)
So anyone here got some ideas to what could be causing this issue with the waitlight???
Thanks Anders/Sweden
