JD4044M
- 1,003
- 93
- Okanogan, WA. 98840
Yes it slips thru the Head Light hole while bent a little till it go across the Turn Light. Then it just pops into the head light hole to stay there.
.Since we are on the topic…..
my truck came with these headlights from the auction.
Anyone know if they are heated? They are LED and stock from the military.
My buddy has them on his 800 series dumptruck and they are brite as the sun but its a blueish white lite theyre 20 times brighter than my projector jw lights for sure !Since we are on the topic…..
SWEET!!Yes it slips thru the Head Light hole while bent a little till it go across the Turn Light. Then it just pops into the head light hole to stay there.
I like them so far. Do you know if they are heated?My buddy has them on his 800 series dumptruck and they are brite as the sun but its a blueish white lite theyre 20 times brighter than my projector jw lights for sure !
No but i will ask ! But you do live in Austin not the real snow belt of I-80/90 !I like them so far. Do you know if they are heated?
I've seen those on plenty of HMMVWsSince we are on the topic…..
Thanks….. didn’t you see the snow storm we got this year?No but i will ask ! But you do live in Austin not the real snow belt of I-80/90 !
I hear ya ! and the lights on his truck were not heated !Thanks….. didn’t you see the snow storm we got this year?
Actually, I do plan to go to the snow and ice at some point….. so I do want it to be an all season/weather truck.
Doug,Since we are on the topic…..
Yeah, the heating wires are pretty visible.Doug,
I can't tell by looking at the picture, but if you look closely at the front lens, you should be able to see very fine wires (like a rear window defroster) applied to it. The heating is done by current flowed through the wire matrix just like the rear window version. The wires are readily visible if you have them. Mine do, but I'm away right now and can't take a pic for you. Mine are different models, but the idea would be the same.
Chris
