- 155
- 158
- 43
- Hills of / TN
I was reading discussions on using a 4L80E without a computer ( going full manual) but my question is will it bolt up to a 6.2? and I believe it will bolt to my transfer case but I may be wrong. anyone used a 4L80?
Just the other day I was putting together kits at the HGM website. Do you have the "new" Compushift? Sport and Pro?I used the Compushift controller and love it. Having different driving modes easily selected was a big g thing for me. Basically my own tow/haul button.
An adapter like this one?Yes a 4l80e will bolt up. I did it on my CUCV. You will need an adapter for the np208. Fabtech sells them. You can use the turbo 400 flex plate. The shifter location is farther back. You will need to drill new holes in your frame to move the shifter mount back.
Sent from my SM-G975U using Tapatalk
https://www.northwestfab.com/4l80E-to-TH400-NP205-AdapterSpacer-Kit_p_3452.htmlAn adapter like this one?
Your np208 is not a figure 8 bolt pattern.Thanks. Googling "fabtech 4l80e adapter" did not come up with that. Not sure if I like that though. If spending this much money on swapping in a 4L80E, why not spent the extra 100 or so bucks for the ORD adapter instead of adding a spacer.
Always thought the NP205 and NP208 were interchangeable. Thanks for clearing that up.Your np208 is not a figure 8 bolt pattern.
