Av3fire
- 37
- 18
- Baltimore, Maryland
I hope this is the correct place to post.
I have a 66 M35A2 that is new to me
I had it so it would start on either, but only idle at 1500 rpm.
I have cleaned the tank (drained and flushed out), replaced all 3 fuel filters (as well as cleaned the gunk out of the canisters), Installed a new in-tank fuel pump, and new injectors.
I have good fuel at the bleed screw at the last 2 filters...... nothing at the injectors
will start on either, but dies immediately.
I have done hours of research and am thinking my trouble lies with the Hydraulic Head
I took off the fuel shutoff plate and the parts inside move freely but when pushed toward the firewall, only returns to about 6 o'clock on its own, can be pushed to 7 with a little effort.
GuessingI need to clean in here some?
Is it normal to have what looks like oil in this area? when i took the cover off, it was almost full of what i am assuming was oil (the PO ran this truck on god only knows what, The tank was a mess - which is what also makes me believe the HH is in need of a cleaning)
I tried to take off the 3/4" nut in the center of the top of the HH to see if a pencil would rise and fall with the center rod, but that thing is TIGHT and i do not want top mess anything up.
Looks like there are lots of very knowledgable folks in here and I am hopeful you guys can help me through this
Thanx in advance...... If this is the wrong place for this post, please educate me and i will move it.
