BigOL3
- 11
- 3
- Kentwood, La.
I have the MEP 003A and need info on what is the acceptable level of hertz, without causing a problem with appliances. I know 60hz is perfect, but generator fluctuates a little as appliance come on or off. If set at 60 but 4ton and 2ton AC kicks on, it will drop to 58+. If on one is on, it will be 59+. If set to 60 after BOTH AC is on, but then AC cuts off, it will go to nearly 62. Can anyone advise the acceptable Hz tolerance?
