- 1,330
- 585
- Quantico VA
I haven't been able to find a thread with a similar issue, so am posting my own: my HMMWV 6.5L TD and 4L80 surges when at idle but in Drive, but only when it is well warmed up. Cold the motor/trans holds idle fine when the transmission is in Drive. When the motor/trans warm up, and I come to a stoplight, the motor surges high and low until I shift into Neutral.
It is a 1997 drive train, sourced surplus and rebuilt/refurb'd and put into my 1987 M998. It has an aftermarket transmission control unit from EX TCU. The mechanic that set up the TCU had done it before on his CUCV with a 6.2 and doesn't have this issue.
Additionally the Injection Pump was rebuilt when I had the Turbo drivetrain installed last year.
I've been ignoring the issue, waiting until I had time to invest some trroubleshooting, and that is now come. It has done this since shortly after I brought it home.
I tried lowering the idle, thinking the torque converter needed to unlock, but that didn't help. It will stop waffling if I give it a noticeable amount of fuel, but I don't think raising the idle noticeably high is a correct fix. Maybe I'm wrong.
If it is related, I have also been experiencing an intermittent (only two instances so far) condition where the motor races when it is in Overdrive and sometimes Drive, and I have been able to get home by manually shifting the gears. Low 1 and 2 work fine, then Drive is sometimes good and sometimes not.
I have probably only driven 500 miles since the drivetrain swap, and there are still some bugs to sort out I'm sure.
Thanks in advance folks.
Bulldogger
Bulldogger
