Iceman3005
- 96
- 28
- Holt, MI
Lift and duration have nothing to do with the plunger seating.Heads will be fine if it is turbo charged, if not, you need to have the hole into the intake. 400 injectors will not work because the cam is different. More lift on the 400, .266 V.S. .176 IIRC. Even if I am wrong on the measurement, the BC is WAY different than the SC, you will have a smoke machine, plungers will not seat in the cups.
Sent from my SM-G975U using Tapatalk
