RUSSELL THESING
- 2
- 3
- FAIRBANKS, AK
I need to ask about my 1985 MV1009 CUCV, engine bay, multi-fuel heaters equipped blazer. I never thought I would have to ask how to find an oil drain plug, but the heat delivery ducts cover the entire bottom of both transmission and engine oil pan.
All I can see of any bolts whatsoever are the bolts holding the pan's themselves. Uh oh, does this mean the whole pan needs dropped, or it has to go to quik-lube for the Super Sucker down the level-check tube's for motor oil and trans fluid. I just got under my new blazer for about two minutes yesterday, and did not see any hint of drain plugs.
Additionally, anyone know of the Rebuild Kit part number, ordering information for the driver side alternator, I think it's the isolated ground 24Volt unit on that side of the engine.
I'm working my way down to the glow plugs and injectors.
BTW, does anyone know where to find a replacement (24V, I think) solenoid valve located on the driver side multifuel heater. It's located on top of the tank, in the rear part, the firewall end of it. It is the second threaded port opening, counting from the firewall side. This peculiar design solenoid valve has two wires going (screw cap) into it, I think I saw "24V" in the yet uncleaned surface, not certain yet. But even a part # would be great to start looking around.
Thanks for any help
Russell
Thanks for any help
Russell
