FIY : Control box knob removal
20,467
and this is the o ring that needs replacing ?View attachment 842588
Guessing - but since all of those parts are called out under Item 14, they are part of a rebuild kit.
I would lay everything out like the exploded view in your picture.
Then, if you take those parts to a hydraulic shop, you should be able to get replacements.
BERZERKER888
894
Daytona, FL
As in the Harbor Freight Hydraulic Shop O-Ring Division?….lol
20,467
Yes sir, I have done the same myself. :cool:
When I finally started to understand that there are metric and standard O-Rings my success rate went way up. Also have discovered that often HF is as good as any. Other times - not so much. Only advantage to a place that specializes in hydraulics often get rubber compounds that are more durable.
20,467
FarmingSmallKubota
1,273
Wapakoneta, Ohio
my leak is coming from under the cap knob, i have replaced all of the 4 orings and PTFE Backer rings. the TM does not show breaking it down like this where are the aluminum pins and what size puller is that because i could not get the cap off with my small puller and the larger one would not go behand the cap
BERZERKER888
894
Daytona, FL
the red dot shows 2 o rings... the 25 year old, hard with squared edges and the new HF Blue O Ring ... 86 the the old o ring.....that was the cause of the leakage behind the knob...20220502_201457.jpg
