Engine starts, runs great. Wait light does not come on. I have been following the troubleshooter in the TM and got to the point of testing voltage to the light itself. Troubleshooter states check for voltage on wire 27. I only get 6 volts at the wire. Trbstr does not state what voltage should be present. At least I have not seen the voltage listed yet. If that is the required voltage, Ill continue on. Does anyone know?
I am going to pull both wires and try getting light off a spare battery but assumed it would need 12, but most suppliers I have seen mention that this is a light is an led and may only need a smaller voltage amount to work. Just didn't want to go further on the troubleshooter without getting another opinion.
My response to the part in blue in post # 3 copied here.
The wait indicator is an LED with a internal 300 ohm current limiting resistor. Wire # 27 is 24 volts from the "RUN" position. The other wire #571 is pulled low (to ground) in the "control box" to illuminate. They can and do go bad. Easy test. Ground the #571 lead to test with IGN switch in "RUN"
This will test the LED only. That to me appeared to be the question. It is controlled by the "BOX" and it's CPU / timers and external sender "TSU"
Assumptions in yellow, can be faulty when working with the unknown. Still leading me to believe OP was experiencing an LED indicator fail as written.
For my time and trouble, I pulled the prints and followed the connections. Silly me.
Yes, there is a lot going on with the "Smart Box" to control the wait LED. IMO... WAY more complicated to glow cycle and start a truck. It could have been as simple as a very warm day with engine not needing a glow and wait OR most anything associated with this system.
It will be interesting to see what the fix is. I would almost say "disconnect the batteries... wait a minute or two, reconnect and check" That how scrambled up the "BOXES" can behave.
Anything is possible, even with the prints and TM's, CAMO Good LUCK.
