- 6,087
- 4,650
We've got a truck(M923A1) that's having trouble maintaining air pressure. It had a couple of constant leaks that we fixed, and several intermittent leaks (heisenbugs).
One of the leaks is the shutterstat. Fan is on. Whistling leak at the external vent port.
While obviously the long term solution is to replace the shutterstat, is there any reason I can't just put the bolts in the fan so it's constant on, and block off the air supply to the shutterstat? This would be a stop gap measure so the truck can be used while waiting for parts.
Operating conditions are low speed, loaded heavy (11 tons in a silage box) and ambient temps in the high 90's.
Anybody got a good source for a new shutterstat?
