Removing the rear diff is what the TM will tell you, and that's a another pain. This is what I did. I had to cut a 4" hole above the T-fitting in order to place a wrench and hold in place. I then cut the two brake lines going into the T-fitting because the lines are being replace so who cares. Then placed a 1/4 ratchet and socket (3/16) to brake it loose. You have to be able to hold in place the T-fitting with a wrench and the hole allows for this. This will prevent damaging the supply line going into the bottom of T-fitting, which it will do if you cant hold it in place. To get in the location for the hole I placed a long extension with a drill bit and drilled from the bottom / underneath the vehicle up next to the T-fitting in order to find the correct location. Which I believe its 36" from the edge of the bed. Then use a hole bit to drill the 4" hole. After that you have access to the T-fitting. Sort of the same concept for replacing the fuel unit in the gas tank. I had an extra panel that I used for a patch. When I purchased my hmmwv it had fore holes for a fifth wheel I patched them up and replacing the brake lines happen to actually be in the same location.
