An overlooked 'spare' for your parts shelf
Light in the Dark
6,435
MA
The return fuel line and the flexible lines (from the fuel filter bowl to the metering pumps) have been covered well enough. The rigid metal lines from the pump to the separator base I have never experienced a failure on... but how about the line from the backside of the separator to the fuel filter bowl? I have recently had to exchange 2 of these out. If that starts leaking (or in my case, hemorrhaging) fuel, you aren't cutting line off a spool with some radiator clamps.
This line is a make item with fittings and a length of hose (17" to be exact). I just had one fabbed up at my local NAPA for $33 with (2) 1/4" JIC female fittings and 17" of hose. Might be smart to get one for yourself in these times of part sourcing unreliability.
Light in the Dark
6,435
MA
Nice find! It sure looks correct 1/4" JIC equates to -4 (and the F would be the female termination). The inside hose diameter is slightly larger than the OEM unit, but of zero real world consequence.
Placing my order now. Appreciate the lookout Zed
Ray70
6,666
West greenwich/RI
FYI, I have all my equipment and generator hoses made by WWW.DiscountHydraulichose.com
You go on the website, design the lines with whatever fittings and hose you want and it's a $10 flat rate assembly fee for each hose.
They ship to your door in 2-3 days.
I have found the best bang for the buck on long hoses for my Lull and backhoe.
a 10' long 3/8 dia. 4000 psi hose with 3/8" JIC ends was just $30 ea.
I have purchased dozens of generator fuel lines ( 1/4" and 5/16" JIC ends ) for about $14 ea. buy in bulk to save shipping costs, which are already reasonable through your choice of USPS, UPS or FedEx.
Of course this only works if you plan ahead... not much help during an emergency.....
WWRD99
1,835
York Pa
I just looked at mine to see if it was leaking or seaping etc...I had a hard time even getting to the filter side connection! I assume pulling the filter off would give better access to it...question also, do you think this would work on the oil line that feeds the oil pressure sensor as well? It looks the same but not sure...if so it would make sense to have a few of these or just swap them out before the need arises.
frank8003
4,987
Ft. Lauderdale, Florida
I already got shipping confirmation on mine, we'll see if USPS manages to actually deliver them.
Now that needs to be in the joke of the day!
USPS even lost my entire first class IRS tax return never to be seen again.
I must send things return receipt or certified now as they "lost" one of my return receipts!
m32825
172
Central Florida
Swapped out my hoses with Surplus Center parts identified earlier in this thread, 12" hose attached to the fuel/water separator, 18" hose attached to the oil pressure sender. The sender end of the oil hose was tough to access. For the sanity of future readers, what's the "right way" to get at that end?
-- Carl
