Floridianson
- 2,512
- Interlachen Fl.
Yea but you have the Deuce and you know about the end fitting on the injection lines. They spin so when we tighten the lines down it does put a twist / tension on that steel line. We do have the anit vibration clamps put on and the injector lines do pulsate with the high pressure. That Cat line does not pulsate. I do not think it is a vibration thing that can be controlled. The engine and governor are bolted together so the only vibration is just what the anything running engine puts out other than the frequency. As said replace with one or the other. Then go get one of the oil change stickers and put on it the mileage and the oil line needs to be replaced in 30 years on you windshield corner out of the way. Occam's razor. Good thing as I said replaced mine and is sold plus going to South America. I guaranteed it would not rust , bust or collect dust for 2 days.I don't have a cat 3116, I a multifuel guy, but all in this thread is good learning stuff.
