- 16,425
- 23,363
- Burgkunstadt, Germany
Guys,
Look at what you have bought, then the plug recpt. Also look at the rear of the recpt. Its a 4 pin recpt, but may only have 2-3 wires hooked to it. The TACOM always tries to use what is in the system. So if you have a need for 2-3 wire plug, and have a 4 pin plug in the system thats what would get used. Look first, before you start planning to not get a light, or hock off the light. I do seem to remember that the T-Light had a Q-disconnect type plug, like the picture. But have not looked at one since the 90's. So my moth eaten brain is not to be relied on.
Remember, know, not assume. Check everything.
