.Anyone ever have this happen? I have been trying to get my rig to run and discovered upon IP top removal an exploded fuel shut off solenoid casing. View attachment 844319
Flag Injection Pump shutoff solenoid for Standyne Roosa Master 6.2 John Deere at AmazonAnyone ever have this happen? I have been trying to get my rig to run and discovered upon IP top removal an exploded fuel shut off solenoid casing. View attachment 844319
No hammer was used on it by me I assure you. Most likely what Mullaney stated above. I just wanted to see if anyone else has experienced this before. It started getting hard to start. Then ran poorly and died several times on the previous owner. Sat for a few years. Then I came along and have been trying to get it back up to par.Looks like someone took a hammer to it.
This IS the one to buy. Don't get the cheap Chinese made ones. This is what I put in mine.
Just ordered one up. I was seeing way too many cheap crap ones. Thanks much!This IS the one to buy. Don't get the cheap Chinese made ones. This is what I put in mine.
I figured it was somewhat on the uncommon side just because it is mine. Seems to be a trending thing with me and my passion projects.I've seen em do it on the old 6.9 and 7.3 idi with with same db2 pump. It will make you scratch your head.
I think He might be talking about constant cranking with no start time after time?.
So, if the vehicle needs to track correctly (steering wheel unlocked) for towing (Tow Bar Towing) . . .
Is the right answer to disconnect the battery to avoid the problem in the picture below?
Or, Should it only be trailered?
OR is it just plain and simple old age and a new part wouldn't have done that?
No, the solenoid is powered (has electricity going to/though it) holding the valve in the open position against spring pressure any time the key is in the ON position (running or not). The solenoid builds heat as it's working.I think He might be talking about constant cranking with no start time after time?
Leaving the key on while towing would be hard on the glow plugs wouldn't it?No, the solenoid is powered (has electricity going to/though it) holding the valve in the open position against spring pressure any time the key is in the ON position (running or not). The solenoid builds heat as it's working.
To unlock the steering the key has to be in the ON position.
That's no big deal when the motor is running, because fuel is flowing through there pulling heat away. But if the engine is not running because you're towing the heat will just build up inside the IP around the solenoid, which shortens its life.
Indeed.Leaving the key on while towing would be hard on the glow plugs wouldn't it?
Yes very. The TM states to never leave the key in the on position for any longer than two minutes or glow plug system damage may occur.Leaving the key on while towing would be hard on the glow plugs wouldn't it?
Kind of what I was getting at was that if leaving the ignition on caused the solenoid to crack, more then likely the glow plugs would have burned out before the solenoid cracked. I think Mullaney is spot on with the old age theory. Thanks to everyone who contributed the info regarding how the solenoid can overheat and be damaged It is good information and I learned something new.Yes very. The TM states to never leave the key in the on position for any longer than two minutes or glow plug system damage may occur.
