- 374
- 686
- 93
- Mansfield, PA
Good morning. I did a search on this topic and did not find anything. So, assuming I did the search correctly and it hasn't been mentioned, I thought I'd share. I checked / changed the air filter last night. Air filter looked pretty good (I changed it anyway) but I noticed that the bracket was loose. Looking closer I have several rivets that are starting to pull through the canister. Now, this is a simple fix but as stated, I wanted to share as I wouldn't want any of them being sucked into the intake and running through the engine. Maybe something you'll want to check on your truck. This picture does not show it as loose - it's on the outside that it's pulling out.
Guy
Guy
